A firmware update for Arlo Pro has been released resolving this issue. Please make sure your cameras are up to date with the latest firmware. See here for more information: Release Notes – Arlo Pro Camera 1.092.0.3.12290 – 9th May 2017
Have you gone to settings, use remove device and then bring it back as new?
I have same issue. After the firmware that was pushed last night (Pro Camera FW 1.092.0.1_11504, Pro Base Station FW 1.8.9.0_11528), two of my Arlo Pro cameras constantly issue false audio alerts. This is even though the microphone is off. Removing the device and adding new has not solved this issue.
? Any other suggestions other than what had been mentioned above?
Did you remove and resync your camera? That has seemed to be the current solution.
The root cause of this issue has been identified by the engineering team. A fix will be made available soon. I will post an update when I have more information.
We apologize for any inconvenience caused and thank you for your patience during this process.
Any updates to this? I have my audio turned off and still receive notifications for audio.
I have the same issue here, when will Netgear release the fix?
Engineering is still investigating this issue. I will post an update when a fix is available.
My firmware has been updated. I still get audio alerts even though audio is turned off on this camera.
WWLightning,
Please contact the Arlo Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
