In my experience exactly 50% of the equipment failed within 6 months and support was not supportive.
Seems any "Arlo Community" questions about problems I have tried to search, result only in year-old reports that have "been closed due to inactivity" which, I am sure is just bull**** from ARLO/Netgear trying to hide the many problems.
So far I was effected by the last major glitch where Arlo/Netgear system where base and cameras were inoperative. Then the app problem where if you checked your cameras or responded to an alert, the app said "timed-out" and required closing the app and signing back in.
Also Arlo support phone contact which I called 2x's and was put on hold a few times on both calls incured a $33.00 cell phone bill. (No mention from Arlo under the Canadian page site there is a long distant charge.
As a disabled person with just over 2 months owning this Arlo Pro 5 camera system, I am dissapointed.
I am unable to climb ladders to remove cameras for these "fixes" that may require several "syncing" attempts.
I would suggest that until Arlo/Netgear remedies these ongoing problems from the multiple complaints lodge that other security systems be considered, and ones with tech support phone lines for those like myself who require a person to explain remedies, rather than the long drawn out back and forth emailings.
Hope this helps any future purchase query of potential buyers.
