Re: Arlo down again???
- Email to a Friend
Day 3... nothing, still can´t log in with my PC
"You can be logged in to NETGEAR Arlo on another tab in the browser. Close the tab before proceeding. You can also try restarting the browser or deleting cookies from the browser before attempting to log in again.."
I hate Arlo
- Email to a Friend
- Email to a Friend
remove this reset that recynk this yada yada yada.....
Still:
and my internet works just fine....
- Email to a Friend
There were several problems that happened all at the same time so that is why there are so many different solutions being offered. One must do the solution for the problem he/she is having.
The first problem that happened was that Arlo made some changes that required deleting all old and expired cookies. This worked for some people but not for others. I deleted my complete browsing history in each of the browsers that I use, (Chrome, Firefox, Microsoft Edge and Internet Explorer). That way I cleated not only my cookies but also cleared my cache in each browser. That solved that problem for me.
Shortly thereafter I noticed that my original base station was offline in both the browsers and on my ios app. I removed the power from my base station for one minute then plugged the power back on and let the base boot back up. That solved the problem for me. I did not need to do a factory reset. My Pro base station never had a problem.
At the same time, Arlo released an upgrade for the Android app which is still not working properly.
I hope this helps you as I do not know the extent of the problems you are having, but hopefully, if you clear your entire browsing history, you will be able to log in to your browser.
Brian
- Email to a Friend
- Email to a Friend
I am having the same exact issue and it's been going on for several days. I can get in my phone (android) but not on my home computer !
- Email to a Friend
Same problem: I can view Live and Library via smart phone but not on Computer...is anyone from Arlo/Netgear going to issue a statement as to when they expect to fix the problem?
- Email to a Friend
As stated in a few places upthread, this may be the solution for browser issues getting into GUI:
For those experiencing an issue logging in, if using google Chrome try pasting this in your url bar and then click "Remove All":
chrome://settings/cookies/detail?site=arlo.netgear.com
If using Firefox, follow the instructions listed here: How to clear the Firefox cache
If using the mobile app, check the app store and be sure you have the latest version available downloaded and installed.
You should then be able to log in.
This was my solution
- Email to a Friend
By the way, I had already cleared the Chrome cache the regular way and it did not fix it, until I did the specific clearing of the Arlo cache as described above.
- Email to a Friend
Joe - thank you so much - it worked ! I used your link and cleared my cookies from my arlo.com and I am now able to login and get my camera view!
I had cleared my cookies through Chrome and still couldn't get in but it was your help that cleared my arlo cookies !
Appreciate your prompt and effective assistance !!
- Email to a Friend
@JamesC I have tried your links and done all the data browsing, cookies & cache clearing, I am still unable to log in to the website to view my camera's. I am in Australia and haven't had a problem until last Thursday when I was logged in and got the message "you may be logged in on another device" I am able to see the "add Device" for a second when trying to login but then it just goes back to login screen. I have this problem on Chrome, Explorer, Firefox and Edge I have cleared everything on all browsers with the same result. Can you terll me when this will be fixed? I am able to login on my Android devices.
Monica
- Email to a Friend
- Email to a Friend
I can also view camera on my mobile, but not on my computer. This is Rubbish!
- Email to a Friend
I had the same problem so I had to go into my browser's preferences and clear the cookies for Arlo and Netgear and restart computer and I got the cameras back on my desktop. I hope this helps.
- Email to a Friend
I cleared the cache and cookies and now everything is working fine. I understand there had been a power outage.
- Email to a Friend
So this morning I am able to login on Chrome again without resetting the base or camera's, I haven't done anything different since clearing history, cache, cookie and browing history mutiple times over the last 4 days. I'm guessing whatever was "broken " has now been fixed by Arlo.
- Email to a Friend
After a lenthy chat with a netgear rep I was finally able to get mine back up the other day, and view the cameras via the android app (setting up my system from scratch basically), but my chrome browser did not work and I got the "logged into another tab" message. Finally after reading thru this thread this worked.
deleting all the files did the trick.
- Email to a Friend
we installed the arlo pro with 4 cameras at my 84 year old moms house to help monitor her. after 2 years of nearly error free service, this system, a couple of weeks ago after an update, it decides to require me to log in or reinstall app. several times a day, this is not good at all. Just prior to that update issue, I ordered and recieved a new Arl Pro 2 with 5 1080p cameras. I will say this, if my moms system issue is not fixed promptly, I will return my new system for a full refund. This is unacceptable Arllo!
- Email to a Friend
I'm having the same issue as many others. The infuriating orange banner pops up telling me my session has expired and I need to login again. The cameras are working. I can access them from my PC, and from my phone for a few minutes after I restart my Android phone. I have done everything, short of remove, and reinstall the batteries. I even did a complete factory reset on my phone, and reinstalled the app, which was a huge inconvience. This is beyond annoying; it is a security issue. If my cameras pick up something at 2 a.m., I'll either have to restart my phone, or turn on my computer to see if it's a possum, or an axe murderer.
- Email to a Friend
Very upsetting yes. Every several hours my phone will say you must login again. I don't have a login selection so I go to setting, applications manager, select Arlo and press. It ask me I want force stop and I press it twice. Then go back to Arlo app, can see and access cameras and library for several more hours. Then repeat it all again. You would think a system that cost this much would be good. Someone is really making money from us dummies.
- Email to a Friend
- Email to a Friend
I'll try that, thanks! Why are we working to solve this instead of tech support helping us?
- Email to a Friend
- Email to a Friend
At this point it isn'e really about down again, but still down as far as I am concerned. The system ican actually see the cameras now, but every time you go to the android app you have to jump through hoops to get to a place where you can log out so you can log back in again. God forbid I had to do something in a hurry, like see anything that is going on. This system breaks on a regular basis, but they usually get this back up within a day or two, still not good for a secutiy tool, but just imagine that your firewalls were down for over a week. This is totally unacceptable. I know someone said earlier this is not a security tool, you need an entire system for security, but to that I say even if my firewalls are up if all my antivirus is out of date, I may still get breached, so yes this is a security tool and I think that many users here expect all parts of their security system to work, not just parts of it part of the time.
- Email to a Friend
Guess you got one of the FEW GOOD UNITS.
