when I am thru scheduling my cameras, the save button does not light up, so i can't save my settings
Thanks in advance
I suspect you may be trying to set a time that passes through midnight. If that's true, set two time periods that stop and start at midnight. For instance:
8:00PM-11:59PM
12:00AM-8:00AM
In the schedule, where there is no save button, or your modes?
In the schecduling section, it lets me put the schedule in but I can't save it, am I doing something wrong
8:00PM-11:59PM
12:00AM-8:00AM
Wow simple, thanks
Got it, I dont have to turn the cameras on do I,they will come on with the schedule right?
Ok, I have the schedule set, turned the cameras on in settings, they won't go as scheduled, did I mess something up
Maybe a screenshot of your modes and schedule would be useful. If the modes have rules for the cameras and are used in the schedule, it should just work. Try a base power cycle just to be sure.
I don't understand any of that,
heres wha I did:
set schedule up and saved it
turned cameras on
after that I am lost.
what else do I do, please keep it simple, I am not very sharp with computers I am suprised I got this far
Oh yea, I don't understand what are rules everybody talks about?
Still not getting it,
set schedule 8 pm to 11:59 pm on
12:00am to 8 am on
turned cameras on
still won't record
Wow you went way over my head, little gray men? I don't understand any of that.
Wow sorry to bother you,
My appologies for last remark, I found the little man, it has no color, I looked for info, can't find anything,
My cameras are set to go on at 8:00pm, and off at 8:am, is that why there is no color on the little man.
If not how do I turn the little man off.
I ment on
After all the above, I assume you have the section through midnight broken into two sections, one from 8PM to 11:59PM and another from 12:00AM to 8AM in your schedule? If so, the running men should be black ONLY in those time periods - between 8AM and 8PM they should be gray.
That is correct
I have another clue, when I go to library, there is only one camera that recoreds, is that any help.
I have checked everything else, Im stumped
