  • 22 Replies
  • 13402 Views
Hondo49
when I am thru scheduling my cameras, the save button does not light up, so i can't save my settings
Thanks in advance
I suspect you may be trying to set a time that passes through midnight.  If that's true, set two time periods that stop and start at midnight.  For instance:
8:00PM-11:59PM
12:00AM-8:00AM
22 REPLIES 22
In the schedule, where there is no save button, or your modes?
Hondo49
In the schecduling section, it lets me put the schedule in but I can't save it, am I doing something wrong
8:00PM-11:59PM
12:00AM-8:00AM
Hondo49
Wow  simple, thanks
Hondo49
Got it, I dont have to turn the cameras on do I,they will come on with the schedule  right?
As long as you haven't turned them off in Settings, the modes will follow the schedule and the cameras will follow the rules in your modes.
Hondo49
Ok, I have the schedule set, turned the cameras on in settings, they won't go as scheduled, did I mess something up
Maybe a screenshot of your modes and schedule would be useful.  If the modes have rules for the cameras and are used in the schedule, it should just work.  Try a base power cycle just to be sure.
Hondo49
I don't understand any of that,
heres wha I did:
set schedule up and saved it
turned cameras on
after that I am lost.
what else do I do, please keep it simple, I am not very sharp with computers I am suprised I got this far
Hondo49
Oh yea, I don't understand what are rules everybody talks about?
Hondo49
Still not getting it,
set schedule  8 pm to 11:59 pm on
                      12:00am to 8 am on
turned cameras on
still won't record
Did you select the schedule to run? Are the running men for each camera black or gray when the schedule should have them active?
Hondo49
Wow   you went way over my head, little gray men?  I don't understand any of that.
Look at the Devices tab. Each camera has a running Man icon that changes color according to what's going on. Black means it's seemed and ready to record. Gray means it's disarmed. Amber means it's recording. This is all explained in the FAQs here - time for you to do some reading and investigation.
Hondo49
Wow sorry to bother you,
Hondo49
My appologies for last remark, I found the little man, it has no color, I looked for info, can't find anything,
My cameras are set to go on at 8:00pm, and off at 8:am, is that why there is no color on the little man.
If not how do I turn the little man off.
Hondo49
I ment on
After all the above, I assume you have the section through midnight broken into two sections, one from 8PM to 11:59PM and another from 12:00AM to 8AM in your schedule? If so, the running men should be black ONLY in those time periods - between 8AM and 8PM they should be gray.
Hondo49
That is correct
Hondo49
I have another clue, when I go to library, there is only one camera that recoreds, is that any help.
I have checked everything else, Im stumped
Opening a case with support will get you going a whole lot faster than this Internet back and forth. I'd call or use chat to eliminate the lag with emails. Use the Contact Support link at the bottom here.
