  • 9 Replies
  • 4699 Views
  • 7 In Conversation
Wallace1
Recently can’t see mode status on cell phone
9 REPLIES 9
Test on a computer to narrow down the issue....   phone or system.
https://arlo.netgear.com
Wallace1
Works fine on iPad and laptop. Just started not working on android phone about 2 weeks ago.
ocdman2020
Does anyone have information as to why i can't get into the mode feature to change it is stuck in getting information? This only happens when using my android phone I can change mode when I use t
cbaileyuk
Same error here in the United Kingdom. Sort this out Arlo . Poor show.
If the Camera tab doesn't have a complete display with all icons, you can't change modes or settings. Either wait for the display to finish loading or try force stopping the app and try again. There's also the web interface to try.
cbaileyuk
The web interface works. None of the suggestions work with the app. And I've tried more. The app is quite broken.
rachel141
Same here, its rediculous. Arlo needs to sort this out now
I use 3 Android devices with different OSes with no problems. I can't help what with what doesn't happen here and doesn't seem to be a widespread issue. All I can suggest at this point is to reboot the phones and reinstall the app.
JessicaP
Hi Wallace1,
Are you still having problems with this on your Android device?
