Can’t review / get mode settings on Android, it always shows “getting status”.
Recently can’t see mode status on cell phone
Test on a computer to narrow down the issue.... phone or system.
Works fine on iPad and laptop. Just started not working on android phone about 2 weeks ago.
Does anyone have information as to why i can't get into the mode feature to change it is stuck in getting information? This only happens when using my android phone I can change mode when I use t
If the Camera tab doesn't have a complete display with all icons, you can't change modes or settings. Either wait for the display to finish loading or try force stopping the app and try again. There's also the web interface to try.
I use 3 Android devices with different OSes with no problems. I can't help what with what doesn't happen here and doesn't seem to be a widespread issue. All I can suggest at this point is to reboot the phones and reinstall the app.
Hi Wallace1,
Are you still having problems with this on your Android device?
