Re: arlo2
NETthisGEAR Apprentice
Hey guys,
Arlo + Arlo Pro + the new Arlo Pro 2 = completely compatible
Per the article I am linking below:
Arlo Wire-Free, Arlo Pro, and Arlo Pro 2 Wire-Free cameras and base stations are completely compatible with one another. In most cases, you can install your new Arlo Pro or Arlo Pro 2 system without making any changes to your existing Arlo Wire-Free system.
Check out this link from NETGEAR's knowledge base:
https://kb.arlo.com/1163530/How-do-I-add-my-new-Arlo-Pro-system-to-my-existing-Arlo-Wire-Free-system
c0co_knucks Aspirant
I have the regular Arlo kit that came with 2 Arlo wireless cameras and a base station (VMB3010) that plugs into my ethernet port on the back of my wifi router. I want to add on a camera or two, and really want the 2 way speaker and sound recording option, since the two Arlo cameras I have don’t have these features. The Arlo Pro & Arlo Pro 2 cameras have these features, but I am unsure if they will work as add ons to my base station. It looks like the base station that the Pro cameras are sold with is different than the VMB3010 station my Arlo cameras came with. Please help me out and let me know if they’re compatible with my base station. Thanks in advance for any help!
Model: VMB3000 | Arlo Base Station,VMC4030| Arlo Pro Wire-Free Camera,VMC4030P| Arlo Pro 2 Wire-Free Cameraarlo.netgear.com | Web Site/App
Master steve_t Master
Yes, you can add Arlo Pro or Arlo Pro 2 to your system and it'll work fine. The only benefits of the Pro / Pro 2 base station are the USB backup recording, which is nice peace of mind in case the internet goes down, and the built in siren, which I never use. Everything else is the same. You can use the Pro / Pro 2 base station and add your original cameras to that if you decide you want to get a kit, if it works out cheaper that way. You can even run some cameras on one base and other cameras on another base as long as you don't have more cameras than your subscription level allows eg 5 cameras for free
Chrisde Aspirant
 Yes I’m trying to figure out if the Arlo pro two is compatible with a Arlo system that I bought in 2015.
Guru jguerdat Guru
Yes. ANy of the Arlo wireless cameras will work with any of the base stations.
Cynthiaandjosh Aspirant
I want the two way audio feature but I have the orginal arlo system can I get a arlo pro 2 camera and have it work with the arlo base station or do I have to get the whole New system??
manfredz Hero
Hero
the Arlo Pro and Arlo Pro 2 cams work with the original base station
dmascote Aspirant
Can I add Arlo Pro or Pro 2 add on cameras to my Arlo system? Can I use both types of cameras on my original Arlo router?
Guru TomMac Guru
Yes and yes
lvollmin Aspirant
can you put a arlo pro camera with an arlo system?
Model: VMC3030 | Arlo Wire-Free Camera
Guru jguerdat Guru
Yes. All Arlo wireless cameras will work with all Arlo base stations.
lvollmin Aspirant
thankyou
amazing! thanks so much for your help!
rmtt Aspirant
I want to add 3 non-pro cameras to my Pro base. Will they connect?
Guru jguerdat Guru
Yes.
rmtt Aspirant
Thanks. Will all the features work the same?
Guru TomMac Guru
The cameras will work with the features they have... obv you can't add audio to a camera that doesn't physically have it
The key is any of the arlo cameras will work with any of the arlo bases
Scotthouck1 Aspirant
Can you combine the Arlo pro and regular Arlo on the same system? For example can you have 1 pro camera and 2 regular ones all working through the pro base and app?
brh Master
Yes, I am doing that..
Brian
teddyb250 Aspirant
Is the Arlo base station compatale with the newer medels, cameras, etc?
Guru TomMac Guru
you can use any arlo camera on any base...
I've run Pro , Pro2 and Arlo all on the original arlo base
bshaw311 Aspirant
im looking to buy an arlo 2. I was wondering if i had two camerias and base station at my house. and take two other camerias and mount at my grandparents house. they have been wanting camerias but not all into electronics. If anyone can assist i will appreciate it .
Eric182 Apprentice
 So what’s your question?
Highlighted
Guru jguerdat Guru
The cameras must connect to a base station via a dedicated WiFi connection. Unless your parents live right next door and can get a good signal from the base you'll have to buy a second base station to connect those 2 cameras to, using their home Internet connection. You can still access them from your own account.
brh Master
You will need another base station at their house. Remember that the maximum distance between the base and the cameras is only 300 feet. They will need to have internet access and set up their own accounts.
Brian
