  • 1002 Views
emoze
is there a simple way to direct connect the VMB400 Base to use ATT cellular (which has 5G antenna 2 blocks from my house )?
have VMB400 base & 4 arlo wifi cameras plus 1 arlo Q+ all connected via slow DSL  via a NetGear DGND3700v2  results of which is arguably not close to  real time when it comes to checking alerts from thousand miles away via iPhone
i am not concerned about the bandwidth use for the few times i might need to see the cameras from far away since i pay for unlimited cellular
You'd need to get a mobile broadband router (or hotspot) with ethernet out for the base.  AT&T does offer the Netgear Nighthawk M6, but it is pricey.
emoze
OK - looked up the Nighthawk - not clear to me how it can RECEIVE signals from ARLO base via ethernet cable & then transmit them to cellular - nothing in reviews suggest using it that way
https://www.downloads.netgear.com/files/GDC/MR6110/MR6110_DS_ATT.pdf
1G Ethernet Port
Distribute Gigabit Internet speeds at home by connecting your
wired devices to the 1G Ethernet port.
It's a LAN port, the same as you would find on a traditional ISP router.   When you connect it to your base, the base will reach the Arlo Cloud over the internet through the mobile router (hotspot).
