Cameras keep going offline. Tried resetting the Base Station by disconnecting power and with app.
My cameras keep going offline. I've reset the base several times by disconnecting the power and with the app my iPhone 6. All will be fine for a little while, then one or all will return offline.
Batteries are charged, all have good connection to our Wi-Fi.
Very frustrating!
When "offline", what are the base LEDs showing? If the Internet LED is green, the connection to the servers is still good so it may just be a display issue. Try force closing the app and reopen to see if there's a difference. Try both cell service as well as WiFi. In addition, try a browser, too - you can use a mobile browser when set to use the desktop version of the site.
