Exactly the same problem except when I tried deleting the app and downloading again but there was no change. Strange but I am getting text messages that motion has been detected but since there are no devices I can not view the videos on my iphone BUT videos appear when I log in from my laptop.
So it must be Iphone mobile app issues.
I haven't seen this at all.
I'm wondering if you are connecting to your home network with WiFi or if you are using mobile data? I've been WiFi connected.
I'll also wondering if this might depend on your location. I'm in the US.
If your using a VPN try turn it off. It worked for me
I had a similar problem and turned off my VPN. So far, problem solved
I’m connected through WiFi at home, in the US.
Same here—I get the alerts but can’t view the videos, until I get to my iPad. It’s OK at home but not when I’m away.
No, I don’t have a VPN. Thanks for the idea, though.
Same Issue. Updated the app. All cameras and recordings disappeared. Add "new device" and the base station found all of the cameras. Two days later, the app shows no devices or recordings. Added "new device" again, all the cameras and recordings came back. Very frustrating. I hope the support staff notices this trend and addresses it soon.
Cameras and recordings all reappeared today and have stayed all day. So far, so good. This is the first day they have been on the app all day. I’m hoping for the best !
Mine came back today and stayed!
Same issue. Three of four cameras disappeared from Arlo app on iPad, but are still visible on Arlo App on iPhone. Note Apple just pushed another security update, I’m running iOS 14.4.1 on iPad 4 and the newly pushed 14.4.2 on iPhone 11 Pro Max. Could this be a compatibility issue?
I added the cameras again using the iPad.  They successfully added.  But still do not show in the app on iPad.  They do show on the Arlo app on iPhone, with new camera names create when I re-added these cameras using the iPad. To clarify: I successfully re-added the missing cameras using Arlo on iPad. They still do not show on iPad. But do show in IPhone, with new names I gave them when re-adding on iPad.
i uninstalled and reinstalled Arlo app on iPad. Cameras still do not show. This appears to be a software issue?
Hellooooo... they’re Back! Just like that, tall 3 missing cameras reappeared on the iPad Arlo App. Have been gone for 3 days!! It’s a mystery.  I did start install process for Apple software update on iPad, to get the iPad up to the same latest version (14.4.2) as my iPhone. But it’s still downloading, has yet to install.
Annoying mysteries are trademark Arlo. They come with the product. Believe me, several years experience and multiple posts to this community. It’s been Arlo software every single time.
I'm having the same issue with my Arlo Pro 2s. First noticed today. Still getting motion notifications, but no devices or recordings in the app. I have the most recent app version. Uninstalled app and re-installed, restarted phone (iPhone X) for good measure. No luck. Husband's Google Pixel 3 is working fine. So frustrating.
Yes, it just updated a few days ago
I have the latest OS system also. Seems there may be a glitch (obviously) as i can start the app, the ARLO page comes up, then it switches to the page where you can select the base station or add devices. Then the red alert button pops up in the upper right corner. Sometimes this is where the app stops. But sometimes, the app then switches to the page to select devices, library, mode and settings at the bottom. Sometimes takes 2-4 seconds to make that last switch though.
Do you mind listing the model of the affected Phone/Devices as well as OS version & Arlo app version.
Thank yuo
Arlo Pro 2 cameras affected (all three that we have)
Model: VMB4000 | Arlo Pro/Pro2 Base Station
iOS14.4.2
Arlo app version 3.1 (2105)
Please stop asking for model numbers. This is clearly an endemic issue.
Please fix this.
And better yet, since you are selling a "security" system, stop breaking it the first place. I'll never buy another arlo again, what a terrible purchase. Since I've owned these, they've been nothing but a headache.
Problem with app was corrected magically without me doing anything. I figured it was an issue with the app update which was not fully tested.
I wish Arlo would at very least post a message saying that they're having problems with certain models and apps whether desktop web app or mobile app. That way we can just wait it out without doing needless fixes ourselves which may have compounded the issue.
Thank you ,
It’s a feature, not a bug. Historically Arlo engineering pushes updates that are not fully tested for customer environments or use cases. Many customers are impacted, sometimes for weeks. Search this community and you’ll find example after example. It’s a serious, consistent culture flaw at Arlo engineering. In my experience, customer = guinea pig. The community is the test environment. We detail what breaks, they eventually fix it, saying nothing. To us, it automagically starts working again. The software will fail over and over, frequency seems to be once or twice annually but has been better lately. Enjoy the ride, tell your friends, it’s fun if you’re bored!
I have a VMB3500r4 base station and running 4 arlo pro cameras. Running App 3.1 and iOS 14.4.1.
Seems like every other day my app will work. It worked all day yesterday but nothing but base station shows today. Been going on and off like this for 2 weeks. Never has camera appear in app for more than 1 day at a time.
@waynebaron wrote:Please stop asking for model numbers. This is clearly an endemic issue.
The reason they ask for a model numbers is that not all models are having this issue and narrowing down will help. I have an Iphone 8 and have no issues.
						Apple HomeKit1
						Arlo Mobile App449
						Arlo Pro27
						Arlo Pro 21
						Arlo Pro 32
						Arlo Secure1
						Arlo Smart102
						Arlo Ultra1
						Arlo Web and Mobile Apps6
						Arlo Wire-Free10
						Before You Buy1,206
						Discovery1
						Features237
						Firmware1
						Firmware Release Notes119
						Hardware2
						IFTTT1
						IFTTT (If This Then That)48
						Installation1,430
						Installation & Upgrade1
						Online and Mobile Apps1,266
						Partner Integrations1
						Security1
						Service and Storage563
						Smart Subscription1
						SmartThings39
						Software & Apps1
						Troubleshooting7,335
						Videos1
