I have 3 cameras connected to the base station and within the last few days one of the cameras has become very intermittent when sensing any activity.
ive tried resetting the camera, checked for updates, removing battery, different location.
It will display live footage.
Hey PMC12,
Have you tried adjusting the motion sensitivity to see if that helps? You can read here on how to adjust it: How do I change the motion sensitivity on my Arlo camera?
You can also read this article to learn how to optimize motion detection on your camera: How do I optimize motion detection for my Arlo camera?
Thank you Jessica, i've tries adjusting the sensitivity without any success. Not sure what else I can test I think the camera has developed a fault
Have you tried testing the motion detection to make sure it's working properly? Read here to learn how to use the test: How do I use the motion detection test for my Arlo device?
I am having the same issue with one of my cameras.
It detects us opening the door and letting the dog out and then 15 minutes later it did not detect someone leaving. To leave you need to walk from the house to the garage and the camera is mounted to the garage
Hi Mnkorn,
Have you tried the links that are shown above to see if that helps? What other troubleshooting steps have you tried so far?
Hi Lastone,
You mentioned you contacted the support team. Let me reach out to you via private message to gather more information from you.
Hey Mnkorn,
You mentioned that you're still having problems even after talking to the support team. Let me reach out to you via private message to gather more information from you.
I am also experiencing intermittent sensing. The 2 camera kit is not even 4 months old and one camera is giving me trouble. Looking at the posts on here there is no solution to this problem
Very disappointed as I am using these to protect an expensive motorhome
