CVR Feature won't replay, out of sync, missing video
Hi @steveski_lax,
When you mention that the CVR timestamps are not matching with the library clips, is this when you're downloading the library clips from the Arlo app/web client?
I have a support case open as well.
Doesn't matter what the client is. All clients get the same result. The green motion timeline is not in sync with the actual time. For the days we are looking at, it is off by 12 minutes.
There is a recording of motion with a date/time stamp in the Arlo library that is completely not in sync with the actual CVR stream. Again, off by about 12 mintutes.
@JessicaP , I've had this issue for years now. The recordings show the green line on the timeline but that's not where the actual time is. I've had it vary from a few minutes to nearly an hour behind.
A few years? That would make it a feature, not a bug! LOL. I am working with the local police department on some footage for a dog mauling that took place, and it is frustrating and embarassing to basically show that your video system doesn't work.
Well, I suppose I was a bit over the top with my "years" but it's been over a year, as I recall.
You can get there, using the green bar as a starting point but then you just have to slog through the timeline to locate the actual recording. More of a PITA but doable. If you can find it before a show and tell, that would be preferable and would waste less time for the authorities but, yes, Arlo needs to fix this. It used to work properly but hasn't for some time.
I have the exact same issue. The timestamp in my library is not the same as on the CVR.
How can it be months and not be fixed? This system is great, but it has bugs. Geofencing is another one, and activity zones.
Netgear, wake up.
Loki2019,
You mentioned that you contacted the support team regarding the problems you're having with CVR. Let me reach out to you via private message to gather some information from you.
