I do not get a user id (email) box when logging in to the web portal (https://my.arlo.com/#/login). I can log in to my account and arlo support. Help!
And that works for me too! Such a small change from the old way - should have figured it out. Thanks.
Have you tried a different broswer?
I tried mozilla, chrome, and edge on microsoft 10 platform - all negative. I get no email entry box on the web portal login screen.
Can you post of screenshot of what you do see?
I click on "Email Address" as usual, the cursor blinks for a few seconds, stops blinking, and nothing else happens. No entry box appears.
On my PC there is no entry box pop-up. Instead I enter the email address and password into the two fields you are seeing.
