  • 6 Replies
  • 16053 Views
jlp1
I do not get a user id (email) box when logging in to the web portal (https://my.arlo.com/#/login).  I can log in to my account and arlo support.  Help!
jlp1
And that works for me too! Such a small change from the old way - should have figured it out.  Thanks.
6 REPLIES 6
Have you tried a different broswer?
jlp1
I tried mozilla, chrome, and edge on microsoft 10 platform - all negative.  I get no email entry box on the web portal login screen.
Can you post of screenshot of what you do see?
jlp1
I click on "Email Address" as usual, the cursor blinks for a few seconds, stops blinking, and nothing else happens.  No entry box appears.
On my PC there is no entry box pop-up.  Instead I enter the email address and password into the two fields you are seeing.
jlp1
