Hi
My app is freezing, and I can’t use the camera. What to do? I tried deleting the app, but it still dosent work.
What phone and OS version? Have you rebooted the phone and tried a different phone or tablet?
So what is wrong with the app?
@Mulletmike wrote:
The app opens and stays on the arlo logo. Does nothing else
Odd, as it is working properly on my iPhone 12 mini, which is also running iOS 15.1.1
Is this a new installation?
Did you uninstall/reinstall the app, or just delete it from the home screen?
Have you checked the permissions in the iPhone settings?
Which version of the Arlo Mobile app are you using?
I can't replicate this on my iPhone 13 pro max, if you can provide the Arlo mobile app version by navigating to Settings > About in the Arlo app.
Can you describe the crashing reference? Is the Arlo app force closing or are your cameras not updating when trying to live stream? Do you have a screenshot you can provide? Does this occur over any other devices or web portal?
What happens if you use another device with your account?
Can you check your iPhone's settings > scroll down until you see Arlo > Select it and see if you have all the proper settings checked on (green)
Does this occur over WIFI and mobile data?
Is your son able to sign in to your phone with their account?
Correct. I would like to see if your son's account can sign in to your phone/app. This will help determine if it's strictly your phone with the issue since you can sign in with your account on other devices.
You can try to restore from a previous backup on your iPhone and test again.
Does this occur on the web portal with your iPhone as well?
So today I googled “ does arlo use Amazon servers”? The answer is YES. And Amazon servers were down.
This whole experience has me second guessing who I am using for my SECURITY cameras. The main issue was not getting a live person to help me and being told I’m not eligible for a live person. Had I gotten someone live and they told me the servers were down, I would have understood. Instead I was left hanging.
in this todays climate and during the Holliday season, security cameras are really important.
