I got an alert today from Amazon regarding the Arlo Pro outdoor power adapter (VMA4700).
"The NETGEAR has informed us that the product Arlo Outdoor Power Adapters (Model No. VMA4700) may have an issue with the connection between the adapter and Arlo Pro cameras may allow water to enter the camera. When this happens the camera may stop charging, cease to work, or overheat. If you believe your purchase is impacted, please stop using the product. NETGEAR has informed us that they will provide additional information to customers."
My question to NETGEAR, is there a replacement cable forthcoming? How would you be contacting me? Through Amazon?
Thanks!
We have recently learned of a potential quality issue regarding the following product that our records indicate you purchased from Amazon:
Arlo by NETGEAR Outdoor Power Adapter - Arlo Pro Compatible (VMA4700)
For more details on what you should do, please contact Amazon Customer Service at https://www.amazon.com/contact-us/.
If you purchased this item for someone else, please notify the recipient immediately and provide them with this information.
The safety and satisfaction of our customers is our highest priority. We regret any inconvenience this may cause you.
Thanks for shopping at Amazon.
Wonder if there is going to be a newer model
I received the same email. I've only had my Arlo Pro 2 for 2 days and had to call about this. I have to say, the help is horrible. I don't care what country someone lives in but if you don't understand what I'm saying, can't complete a sentence and don't know anything about the product, you shouldn't be answering a help line, only to repeat back everything I say. (end of rant)....I called twice and was told that there was nothing wrong with the adapter. I don't want to use it no since I don't believe that Amazon made up the email. I email Netgear also so maybe there will be a response. I'll post if I get a reply.
I just purchased 2 from Amazon and I had only tried 1 of them. That one will need to go back as it was sometimes showing that power was not connected on the camera. I also had a power drain that may have been from having to use the camera inverted with the power cable. It only had 1 bar on Wireless connection and being outside in the cold it was loosing charge fast even when it was showing power. I may return both and just use the cameras outdoor on battery. Since disconnecting the cable I have not seen an unusual drop in battery percentage.
Oh great. I just purchased this for my new cameras, that just arrived. I received the same notice. This is a deal breaker for me if I can't plug these in. Changing the battery pack is a pain in the neck (I have 2 cameras currently). I will have to look at other cameras (i.e. Nest, Logi Circle 2, Ring) if I can't use these without power.
That's all supposition with no proof.
I have been using this cable for some time without any issue. Granted, I'm not in a very wet state. Worse case, the camera breaks. Better than getting out a tall ladder to replace the battery.
So I wrote Netgear about this and they wrote back telling me that I couldn't use an indoor adapter outside. They obviously can't read since I told them it was their outdoor adapter, which I do not find on their site for sale. Did they pull it off the market?
They also said they have no information saying there is a problem with the adapter and want me to send them proof of the letter.
This is not a good start for me with customer service.
jguerdat wrote:That's all supposition with no proof.
Don't be so naeve or dismissive of peoples issues. I've had nothing but problems with my Arlo Pros' and charging; I always thought it was the camera, so it' wouldn't be unjustified that actually its a problem between the camera and the power adapter.
The proof is in the email from Amazon, they wouldn't send it without good reason (and to two people none the less). Whos to say this isn't contributory to the below?
In response to the question the OP raised to Netgear, then this is also not unsurprising. I've never come across such as mis-informed, poorly constructed support channel as I've had with Netgear. You get different responses, from different people on different days, and from different parts of the organisation. Communication is NOT their strong point, whereas taking your money is.
Seems lots of people are getting this same mail.
Not that it will ever happen, but there needs to be a formal announcement from Netgear on this. @JamesC
This is product recall territory.
It also has the possibility to damage the camera itself and lots of these people that have 'not a genuine arlo charger' issues could be related.
Was planning to this weekend and have contacted the Arlo team, sadly these always seems as hopeless as this forum help wise from Arlo.
Don't forget that this can void your warranty.
jguerdat wrote:Don't forget that this can void your warranty.
Wondering whether either power adapter or camera warranty would actually apply and get full replacement of a damaged camera by Netgear.
Just had a call from the customer services team at Netgear to follow up on a different issue (probably one of the most helpful people so far I've come across in Netgear), but it was interesting to note in my conversation that although this hasn't been raised internally and she would follow up herself as it's in their interest to, that when these type of issues are flagged the Community Team (JamesC, Brad et al) have an obligation as employees of Netgear to raise repeat issues or concerns (just as this is) into the engineering team at Netgear.
I'm not convinced this happens personally, so the question here is what is the community manager doing about this (and other issues)
I would think that damage caused by proper use of a Netgear device to another Netgear device would be covered with no issue. If someone has an issue like this that's not resolved satisfactorily, yell loudly both here and using your case.
Hello
Just a note of caution, I had exactly the issue described on Amazon's email.
The Camera and the Power Connector burnt.
Pls see pictures attached.
Opened a case with Netgear help desk, wating for a resolution.
[]s
Wow! Haven't seen that before. I had an issue with water getting into the camera connection and causing corrosion but nothing like this.
Yes I couldn’t agree with you more, that’s how it should be.
Yeap! Check-out Amazon's cutomer review on this item. There is another picture very similar with my case.
His description is eaxcatly as mine, the camera and the power adapter connector burnt.
Amazon removed this item from the store and I got the message below.
[]s
Sincerely,
Customer Service
Amazon
www.amazon.com
We’re you running the camera in CVR mode when that happened ? Just wondering if a constant, long-term, high power power current flow triggered the burn ?
Hi
No CVR mode, only the basic plan with short video storage.
[]s
Adriano
aandreol wrote:Hi
[]s
Adriano
Was this with Arlo Pro or Arlo P2 camera?
