Bought the Pro mainly to have the ability to speak through the camera when someone's at my front door the sound out of the Pro can barely be heard I would say you have to be two feet away to be able to hear. a
Anyone experience this?
If you mean the recent iOS app issues, that's fixable via an updated app.
I didn't say the current iOS app fixes the problem. I did say that an app update is what will be needed.
A new version of the iOS app that resolves this issue is now available. Please make sure you update to the latest version from the App Store. See here for details: Release Notes - iOS App 2.4.1 - 24th May 2017
Still weak audio on Android - When will the Android app be updated to fix the problem as you've done with the iOS version?
Hey James, when will the Android update address the audio too?
A new version of the Arlo mobile app is available for download from the Play Store. Please be sure to download and install the latest version.
Im a new Arlo Pro user. I use a Samsung Chromebook Pro and Samsung S6 phone. Neither has adequate speaker or microphone volume. Since this is a new purchase, I have loaded the latest firmware. This is a major investment so I'd like to hear what the tech people have identified as the cause. I realize a solution has not been released yet; but I would hope you folks would at least know the cause of the problem. This isn't a "user" problem.
Can't speak for the Chromebook but the issue is the inability to increase the gain on a phone. Use of a computer usually fixes that - check the Chromebook settings to increase the gain (maybe a checkbox). Since the 'book is basically a large Android tablet, it may not have that setting just as the phone doesn't. It's a hardware limitation that you can't do anything about.
Check all of your device settings and be sure the volume is turned up. If you're still experiencing issues, please contact the Arlo Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
Still very poor audio volume with Android (S8+/HTC/S7+/PIXEL). After following the Moderator's adivce - contacted customer support - THEY DIDN'T KNOW THIS WAS AN ISSUE!!!!!!!!!!! Never heard of it.
Well - I'm bored and exasperated now, trying to fix a £1200 camera system from such a large company. VERY POOR SHOW - SHAME ON YOU. I'm taking my system back today as last day I can get refund for defective goods.
Come on Netgear - Pull your socks up
Iseeyou123,
Firmware updates should all complete automatically.
If you're still experiencing an issue with volume after exhausting the troubleshooting steps above, I encourage you to contact the Arlo Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
I jus installed my system and I'm also having issues with the audio. This MUST be fixed guys! This is a good system, but it loosing it's reputation just because Netgear cannot get their act together. If this issue does not get fixed, I will also return the system and go to something else.
If you are still experiencing this issue after checking your device settings to make sure there are no volume issues, please contact the Arlo Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
