Bought the Pro mainly to have the ability to speak through the camera when someone's at my front door the sound out of the Pro can barely be heard I would say you have to be two feet away to be able to hear. a
Anyone experience this?
You need to call support to help you .mind appears to be OK
I am using iPhone 5 with ios10 an iPad 3
Using iphone5 with ios10 and iPad 3
jguerdat wrote:I suspect a long-term fix will be in place but we have to wait for the app to be updated to support that. Since the computer works fine, it's an app problem.
One thing you can do is to make sure you speak loudly and directly (~2 inches away) into the actual mic opening. It can be cumbersome and isn't the way it should be but until a fix is applied, it's the best you can do.
Yes It does seem to be an app issue as it works fin from my laptop. I have all the latest firmware, apps etc and it is still not usable audio level
Question - is the mic volume able to be boosted on iOS? It isn't in Android but would likely solve the issue.
I don't mean in the Arlo settings but in the phone settings.
I received an email from an open case that I have for a mic issue not being available (push to talk) for my Android. They updated the app. Not sure if it fixed the volume issue. Haven't had a chance to really try it. They suggest removing the app and then downloading the new version. Give it a shot and tell us what you think.
I just installed the arlo pro system. firmware updated to 1.090.0.0_9945.
Audio is so low it can't be heard coming out of the camera speaker. Return response from the camera is faintly heard on iphone. Audio is set at 100%. It looks like a common problem that has not been fixed. Any ideas?
Does it work ok with a computer? If so, open a case with support so that your voice is added to all the others who experience this issue when using a mobile device.
Yes, make sure you put in a support ticket. It's a longgggg process. They are well aware of issues with this. Make yourself heard by contacting support.
And there is 'video & Audio' heading. Under that is 'video settings' and ' Position Mode' . No audio settings anywhere!
I bought it for the two way speaker! Ugh!
Suzanah1,
Under settings for Arlo Pro there are two separate clickable options for Video and Audio settings. What is the model number of the system you have? It sounds like you may have the original Arlo system (no audio), not Arlo Pro.
