Bought the Pro mainly to have the ability to speak through the camera when someone's at my front door the sound out of the Pro can barely be heard I would say you have to be two feet away to be able to hear. a
Anyone experience this?
I went back to the testing lab. On my Windows 10 PC using Firefox, I was able to use the audio with the Arlo Pro. The sound did come through the speaker much louder than on the iPad and Android phones. I suspect that the issue is more of mobile app and firmware.
Mobile app - There appears to be inconsistency and problems using audio feature with majority of the smartphones and tablet.
Firmware - while the sound is much louder, it does break up every now and then.
Overall, it does appear to be more of software related issues (firmware and apps) that needs some attention from the company.
Just had a live chat with support and they told me there appears to be an update sometime next week . That looks good .Hopefully the will do it
Glad to hear there is supposed to be an update but I'm returning mine this evening at Best Buy when I get back from work.
sorry to hear you are returning your Pro. Hope everything goes well for you. For me I am hanging in there .
No I have not tested mine yet. Glad to hear that someone has seen some impovement . I will test mine later . Hopefully the is the begining of the fix
Was there a fix issued? The audio in all of my cameras is basically inaudible.
Trucha wrote:
I tested mine yesterday and seems like there has been an increase in the speaker volume. Can anyone confirm?
Not sure I am just responing to .the last post . I was told that the fix has been discovered ,but up date will come sometime next week
That e mail came to me from someone at support ,I think ,by the Name JamesC
I returned mine yesterday. Other than this 2-way audio issue I really liked the system. If/when it is fixed and widely confirmed on the forums by users as being so, then maybe I'll purchase another set.
Hi everybody Listen to this . I just got off the phone with support and they help me fix my low audio situation ,and it is all taken care of theu help me reset everything to were my audio is loud and clear . There was and up date and I receive an e mail so I called so now we are back in busness .
How do we get the update? what were the steps you followed?
I called support and they help me update and now my sound is great . So call them 408-638-3750 and hit number 2 option . good luck . A lot of people have returned theirs and if they would have hang on they would have had the fix taken care of . Ours sound is working great
What version of firmware is on your camera's now?
If this indeed fixed it would be nice of Netgear to post an official update or statement and the steps/ method to apply the fix.
Bob
This firmware version has been available for at least two weeks now but has not solved the low audio problem for me. I am using Iphone 6s and IOS 10.1.1
Bob_1963 wrote:If this indeed fixed it would be nice of Netgear to post an official update or statement and the steps/ method to apply the fix.
Bob
I can also confirm I have this firmware and speaker volume is improved.
Yea mine works great . I am not sure when Netgear had this fix, but I am glad it is taken care . My wife have tested it at different location am it was fine . I do not want to ask why just care that it is taken care and working
prof57 wrote:This firmware version has been available for at least two weeks now but has not solved the low audio problem for me. I am using Iphone 6s and IOS 10.1.1
Bob
yes I can confirm no improvement with meter. As far as support, if you bump up a tier they are syaing the firmware update is not related to sound issue and they are still working on that, and concentrating on the app -- which has not changed for a month
