Arlo Pro live view continuously
The problem is random and i use to monitor my baby diring night hour. But I as well doubt the realiability of this model and hope there is way to fix it.
azraelmds wrote:
I using Ipad with live streaming for the camera. But it seem intermittently hang or appear image frozen. i have to close the apps and reopen it so that to make it work again.
Is the Pro plugged in ?
Many Arlo cameras do shut down at the 30 min mark...to preserve batteries, both Arlo and Arlo Pro do this
A few have tested the duration of live stream time and while it varies, results are pretty close
Also you cuould check the sleep timer on the ipad to make sure it's not turning off after time
True.. This is also how I benchmark my system by playing continuously 2-3 times in a day to see how the cams hold up... I'm connected wired using wemo with battery inside the cam.. Indeed I agree with you that it intermittently hang or appear image frozen once in awhile for me. However, I don't do it all the time so I accept the way it is for now. We are all hoping that someday these glitches will be fixed.
So like to ask if Arlo Baby has no that issue that i know it can stand for couple of hours and is good enough for me., In the case i didnt apply the power as well? Thank you!
The Arlo Baby doesn't have a time out feature as it was designed to mostly run on ac ( tho it does have an internal batteery good for a few hours at night and double that in the day ( ir lights drain more ))
So far the most I have run the Baby is about 4-5 hours and have not seen many issues... still a slight bug they are working on re some pixel noise at bottom of streamed picture that comes and goes...
Ive been happy overall with the baby and its feature for the grandkids ( btw, tested on android S7 and Ipad )
Why i'm asking this as sometime i just like to mobilize the camera to difference place with using battery..
Thank you!
