Bring Arlo base to a high speed internet location to update firmware
Hello, I cannot upgrade my firmware due to a slow internet where the system is installed. Would it work if
1) I take the whole system to a home where high speed internet is available
2) up grade the firmware using that network
3) go back to the slow internet location (where I want utilmatly to use the system)
4) hook the base to the network and sync everything?
Tks for your help 🙂
Yes. That would work
