  • 5 Replies
  • 5401 Views
q8kiwi
hello
i am facing problem with connect camera with base station model : VMB4000
i follow instruction but no way to connect . as i see in base station the sync status LED on the base station blink green thin stable with amber color after sync finish . then no any connect happen !!
please advice me what shuld i do .
thanks alot
best regards
saud alattar
steve_t
Master Master
Strange. An amber light for the camera icon on the base means the base needs to be claimed. Do you see the base station and the base station siren in your Devices list and no cameras?
5 REPLIES 5
steve_t
Master Master
Remove all devices via the app. Add device and add base station. Once that's added, sync the cameras
q8kiwi
hello steve i do it many times still the problem not fix even i do factory reset still no any change . thanks steve
steve_t
Master Master
q8kiwi
hello
it work probably now . i make mistake that i do factory rest and sync camera befor sync base station .
i am sorry . every think ok now .
thanks alot
steve_t
Master Master
Great that you're up and running. Don't worry, a lot of people make the same mistake. It's a weird system that it can even allow you to do it incorrectly to start with
