Arlo|Smart Home Security|Wireless HD Security Cameras|NETGEAR
Re: Arlo Pro Local Storage Auto Overwrite Not Working
FWIW: the Arlo techs included my BS in a test of a firmware mod for this issue, I just checked the 8GB USB stick 30 minutes ago and rewrite is still working as I'd expect, so I belief that an update, once ready for general production, will address the reported issue.
Message 26 of 53
I have the arlo pro base station. And the usb overriding does not work for me. I discovered this issue in August when I decided to take out the usb and view old content. I found that the last recording was in MAY.. I also found many old empty folders..
I that that maybe because I viewed the usb in May it messed up the usb.. cause the usb is suppose to only delete content that arlo recorded but if it thinks it isn’t then it won’t delete resulting in the bug.. so I reformatted the usb in the base station and observed it fillling up.
I wanted to see if it would reach the max storage and delete some. But it doesn’t. It says full and no longer appears to save to usb.
Usually when someone triggers the cameras, in the arlo app, the usb icon turns yellow to indicate it is saving to usb.. but now that it is full it doesn’t do that..
Please fix!!
Please allow the tollerace to be higher than 5 MB! Some recordings are larger than that!
Model: VMB3000 | Arlo Base Station
Message 27 of 53
Arlo will not overwrite USB stick because of the 5MB free space requirements
Please fix!!
. My unit reports a full USB drive but computer shows 10.4MB free space.
Message 28 of 53
This issue should now be resolved with the latest Arlo Pro base station firmware. You can check the release notes here to be sure you have the latest version: Arlo Base Station - 1.11.9.0_26520 - 14th October 2018
Message 29 of 53
This has not resolved for me. Firmware seems to be updated. When drive gets full, it stops recording. Also compared to last firmware, the “safely eject” and “ format” button disappear causing me to do a reboot in order to make those buttons reappear.
Message 30 of 53
Ronsteele73,
What version firmware is the base station and camera running currently?
Message 31 of 53
1.12.0.0_27099
Vmb4000r3
That’s for the base station
Message 32 of 53
Highlighted
Ronsteele73,
Due to the amount of issues described I have opened a case for you. I will contact you via private message with further information.
Message 33 of 53
This issue is not resolved for me either. Once the drive is full, it quits recording and does not overwrite.
HW Version VMB4000r3
Firmware 1.12.0.0_27099
Message 34 of 53
Notrab,
Have you tried to format another USB Drive through the base station? What firmware is the Base station running?
Message 35 of 53
Re: Arlo Pro base will not Auto overwrite files on USB drive
I have the same problem. The base station will not auto overwrite. I use the Arlo pro in my shop and my 180GB hard drive gets full in almost every 2weeks. I have tried all I can but it will not overwrite.
Message 36 of 53
Yes, and I added the FW above. It's the latest version.
Message 37 of 53
Ajapona,
What trouble shooting steps have you preformed? What firmware is the base station & Cameras running?
Message 38 of 53
Notrab,
  Have you tried contacting customer support regarding this issue? I have attached the link below for you - Arlo Tech Support
Message 39 of 53
I have not received any further communications regarding this issue. I have also replied to PM
In addition I have included photos of the issue
Message 40 of 53
back on 11/8 when this thread was revived, i pulled my 8GB san disk cruzer and checked the dates. overwrite is working for my BS VMB4000r3, Firmware 1.12.0.0_27099
Message 41 of 53
same problem, still. every time I look at the usb status it is near full and Disabled even though it is configured to overwrite!!
Message 42 of 53
Virtuoso
Same for me. Once the usb stick fills, recordings stop, no overwriting.
Message 43 of 53
@RChobby,
@unhappyarlouser
Message 44 of 53
Virtuoso
No, I’ve not contacted CS.
I’m still trying to recover from the last times I called CS. Over several phone calls on multiple days, many hours on hold, several email follow ups, for geofencing problems and no solution. When I get a few days vacation perhaps I might try again, but probably not.
Message 45 of 53
@RChobby,
Message 46 of 53
Yes, I did get a case opened. thanks.
It looks like my 16gb usb memory is nearly full with videos dating back to April.  It looks like it was still getting new recordings up to just a few minutes ago, but the app was showing the USB Memory status as Disabled.  there is an app bug in there somewhere.
The USB memory has over 4000 videos. The strange thing is that June, July, September each only have ONE video (obviously that is wrong) and nothing for August. So I did have a real interruption somehow, or the algorithm that chooses what to overwrite went off the rails.
Message 47 of 53
I am also having the issue of not overwriting. Have latest firmware.
VMB4000r3
1.12.0.0_27099
Message 48 of 53
Hey @Mtam,
Just to make sure, after you connected your local storage driver, have you toggled on the "Automatic Overwrite" feature? You can find this by going to Settings > My Devices > Choose your Base Station > Local Storage. Otherwise, also try using a different local storage driver and see if it still persists.
Message 49 of 53
I did toggle the "Automatic Overwrite" feature several times with no help. I will try another USB drive and report back. Thanks.
Message 50 of 53
