Arlo Pro Base Station Cannot Be Discovered How Do I Know If It Is On The Same WIFI Network?
arlo pro base station cannot be discovered from app. How do i know if it is on the same wifi network ?
2 green lights on the base station
reset to factory settings already
next step?
But all 3 lights green on base a middle one blinks so it communicates with the internet. But the app does not find any devices.
Why do I have another WiFi netgear 78 and what’s password for that.
So far this box is worthless
That sounds like your system is already set up. If so, you can't discover the base since it's already claimed. Do you have anything shown in Settings, My Devices?
nothing showing in my devices
Is this a used or refurbished system? It could be that the base has already been claimed by a previous owner which is why you can't claim it.
bsfoster,
Are you connected to the same wifi network your base station is plugged in to?
Nothing changed.
You didn't answer this. In any event, swap at the store.
