Since moving alarm into upper right corner, I have a very low sounding alarm? Instead of 100db it might be 40db!
I'm not getting any alarm at all.I hope they get this fixed. The alarm feature was a big selling point for me!
I have to agree. I just tested this for a different post and thought it was weak. I don't see a volume control anymore, either, except in modes and rules.
Another person sent me a message saying its working on thier android but its not mine so something is not right. Thank you for your info to.
Today I was watching a live feed and clicked on activate siren, I could barely hear it from next room, walked over to the base station picked it up and swear I could put it to my ear if I wanted to the volume was so low! I could not do this a month back when I bought it, it was very loud.
I cant find anywhere to adjust the volume apart from Mode > Edit. Which is set to highest.
Is this related to latest update? Any info / experience regarding this is appreciated.
Interestingly, I tested this yesterday and found what you did. Just tried again and found that the app produces a low sound but the web produces full volume. Not sure why there would be a difference.
Open a case with support:
THIS IS FOR VMB4000. SO MY ISSUE IS...I HAVE FACTOR RESET THIS SEVERAL TIMES AND SAME RESULT. WHEN I SET ALL THE CAMERAS UP TO SET OFF THE SIREN FOR AUDIO AND MOTION, IT SETS OFF THE SIREN FOR A COUPLE OF DAYS PROPERLY THEN IT STOPS. THE SETTINGS ARE STILL CORRECT AND INDIA SUPPORT IS USELESS. FOR CLARIFICATION, THE SYSTEM WORKS PROPERLY FOR A DAY OR TWO THEN THE SIREN NEVER WORKS AFTER.
Also why Arlo don't give user the option to change volume for manual "activate siren" is beyond me.
Talked with support on chat & found out that on my samsung note 5 phone & samsung tab s3 tablet, when u test the alarm, it is very low, but walk in front of camera or make noise the alarm is loud!!! Tested my HP Pavilion comp & wifes IOS 10.5 pro tablet it was loud with test and walk or noise in front of camera!
She was sending this info up the line to be checked.
Thank you so much for your message. My phone is a Samsung S5 and my tablet is an rca. On the old alarm it sounded very loudly at the base but nothing now. And I can't hear anything at the cameras either. Did your base stop going off too?
My daughter has an I phone 8 so I'll get her to see if she can get it to work when she gets off work. I've also tried everything you have and still no sound at all. Not even low sound at cameras or the base. I really can't afford a new phone so I guess if that the issue I'll just have to live without a alarm. Thank you for being so helpful. I feel stupid trying to sort it out!
I finally figured it out! All along it was because the internet was not plugged all the way into the base station. I have no idea why everything else was working. I tried it in motion detected alarm and its way to loud and You should have saw me trying to turn it off! I set it to were I have to activate the alarm and its great! I do believe the alarm would scare off an intruder because it scared me off Ha! Ha!
Thanks for your help! I finally solved my issue! I didn't have the internet plugged all the way into the back of the base station.
New problem. I usually test my Arlo base station's alarm once a month or after every app update. After this last update, the alarm still works but it is no where near as loud as was before this last update. The sound level the alarm is now producing is barely audible from 20 feet and by no way of the imagination will it ever scare off an intruder. However, they may die of laughter when hearing this alarm.
Anyone else experiencing this problem? Also, is there a fix for this?
A few existing threads here. I find that using the Android app to manually turn the siren on results in low volume. However, using a browser results in normal volume. No idea why the difference.
I have tried and it makes no difference. It appears that the app is setting the volume when manually activating and there's no way to set it louder. Open a case to raise awareness.
See my photo of just how. loud the siren is when using the Android app.
It's not the Internet connection. I've tested this with both the Android app and a browser. The pp is soft, the browser is normal.
I've opened a ticket on this issue. The development team is currently investigating. I will provide an update as soon as I have more information.
Hi all, I noticed the new update today which removed the slide-down alarm and replaced it with the red shield at the top. I thought i would test the alarm and noticed that it was noticeable quieter than when I first tested it when I bought it a month ago. Is anyone experiencing this? It could be me, but I also noticed the sound sounded more like a smoke alarm rather than a alarm siren. Did this change too? I'm kind of having doubts that this would deter anyone.
