Arlo Pro - Library Is Showing Separate Previews For An Alert
  • 2 Replies
  • 2433 Views
DarciK10
I have 3 cameras. When I look at my library it shows three separate previews from an alerted action it recorded. When I click on Driveway it will show driveway. If I click on Front Door it still shows driveway. Same if I do the Backyard. Will show the driveway. I reset the base and also toggled off all devices in the app and back and on and same thing keeps happening.
steve_t
Master Master
Sounds like an app issue. Did you try force quitting the app and opening again and looking? Have you look at your library through your web browser on your computer?
steve_t
Master Master
DarciK10
Thanks for the help! I didn’t try on the pc but the next day the app was working fine after trying everything I mentioned.
