Since moving alarm into upper right corner, I have a very low sounding alarm? Instead of 100db it might be 40db!
Message 1 of 78
13,867
77 REPLIES 77
I just did a test using the Android app. I am happy to report that the volume is very loud again. I'm not sure they did an update but right now it is working.
Message 76 of 78
10,601
I confirm. It is fixed. Siren activated manually from Android is loud as it was before 2 months ago. Good 🙂
Message 77 of 78
2,169
I checked mine and it's fixed too! Thanks arlo. Please put an alarm on each camera. That would be the best improvement ever!
Message 78 of 78
2,155
