Every morning for the last week my Android app informs me the base station needs to be updated. Each of the five cameras is disabled and displays a button to Update. If I press one, the app exits.
If I go into the base station settings I can update from there, but it never seems to. After a few minutes the message goes away.
Thoughts on how to fix it?
My problem is now resolved, hope everyone else’s also. It had to do with base stations having participated in Firmware Field Trials (sometime earlier) and running on a specific firmware version.
Thanks to Shayne for helping us with this issue.
Have seen this too.... 2 days in a row but not today.
In settings, go to base and toggle to allow the update... it should do it overnight.
I've gone into the settings for both the web app and the Android app, and under the base station settings, I see no "toggle" for allowing updates to firmware. It's telling me there are no firmware updates. Here is my version:
Ok same version...
when you see the update message on the screen.
It’s. Settings/ devices / base / device info/ then should be an orange triangle which says firmware update...click on that then click on ok to update
Thanks for responding again.
Regarding your suggestion for the update, that is the process I have been following every morning for the past several days.
The app shows "Firmware updating" for about minutes, the lights flash a bit on the base station, then the app appears to go back to normal. Next morning, I have to do it all over again. The firmware has shown the same version the last 5 days...
I THINK my version is the latest. If it is, something is triggering an update command. If it's not the latest version, then the update is obviously not working.
Annoying. I may have to delete the app and reinstall at this point...
Same here....
have two Pro Stations and they alternate (each day) prompting for the update, then......nothing happens and same process next day over again.
Strange thing is, base stations have different firmware version showing, probably one must’ve updated already while the other hasn’t.
Similar problem here. For the last 4-5 days, I've received notice that the base station firmware needs updated. Either on the notice (which initially appears on the camera views) or via the Device/Settings section, I've selected to update firmware. Nothing happens, and it remains on the old version. So then in a future start-up, I get the message again. Frustrating, as despite the firmware upgrade, it then works for a day and then goes back to an issue the next day.
That's exactly how it's working for me. I even tried to "add" another camera, which forces the base station to look for updates. It reported it found an update, started "installing", then 5 seconds later was done. Same version.
It's interesting it's not a universal camera. I wonder if it's the older models only like mine...vmb4000r3.
Ok Arlo enough of this already, it’s been over two weeks now this is going on. Is it possible to screw up every other firmware upgrade this way, who/which department is responsible for this and why is it being ignored ?
Something new every day, they never stop surprising us.
Hi @Paul_FCCL
Please contact the Support Team to further investigate this issue with your base station. You will find several options for contacting support in the provided link. Arlo Tech Support
@ShayneS :
thanks for providing the case #’s, but after two attempts (got disconnected during first chat session) nothing worked.
Support people must be going over a script of preset instructions to help with a failed firmware update, asked to go through the basic steps, but this is different. They asked for a screenshot of the error message, while there’s no error message, after you explain that over it becomes frustrating.
Last, I was asked to reset the base station......re-add all cameras and of course re-do all arming modes. Chat session disconnected again.
Did all that........(stupid of me) and we’re back to the start of the vicious loop again.
How else can this problem be brought up to the technicians who can actually fix this problem?
Were you able to resolve this problem?
I still haven’t, finally gave up after so many attempts with support. I’ll just deal with the daily annoyance caused by the update prompt, far less aggravating than going through all this nonsense.
@ShayneS :
last case #42035376 got disconnected from that as well. Last question I was asked was to perform a speed test of my internet (i do have a high speed 150 Mbps and test result came to 199 Mbps) and upload screenshot, just as I got disconnected. Maybe my internet speed is too fast? 🙂
Attached is the screenshot.
it appears to me they’re on the wrong track if that’s the type of question they ask.
Thanks for your help.
@Boss281 :
my current base station firmware is # 1.16.3.3_3572_b349f52 and the one trying to update to is # 1.16.4.0_3616 which barely flashes its info when attempting to update.
@Boss281 :
yes the VMB4000r3
i have two of them, the other one has a completely different firmware version and it hasn’t been trying to update at all.
I read through this thread this morning (10-31) and I, too, have been experiencing the same thing. I was hoping someone had an answer, but obviously not.
base firmware is 1.16.3.3_3572_b349f52 and the cameras firmware is 1.125.15.0_35_1191
I click on the response to update but nothing happens. I look at Device Info, Firmware and it states “No Updates Available”.
I am using an Apple iPad, iOS 13.7
Just a note I've started receiving the email suggesting I mark this solved. As of yet is it NOT solved (11/2/2020)
Not solved. It still asks for updates every morning.
I have been seeing it too for a number of days.
Allowing the update or power cycling the base does not solve the issue.
Seems to possibly be isolated to anyone who are field trial users.
Arlo are aware of it.
