Hi. Just updated to 2.5.0
Now I don’t get push notifications. Also my schedule displays the wrong thing i.e. if the time is 17.00 and the schedule is set to be armed the Mode screen shows the clock icon but says disarmed.
Arlo is there a fix on its way?
This system is not cheap!
I have already given up on geofencing as it just doesn’t work and is totally unreliable. However the schedule and push notifications are essential and without them the system is about as good as a chocolate fire guard.
I don’t feel my property is protected as it should be.
FYI iPhone 8 iOS 11.3.1base station reset and still no joy
Issue persists with notifications on iOS with app version 2.5.1. When app is reopened after minimizing after short period of time it says that password is incorrect. Closing the app and reopen works for a while (no need to insert password) but after a while it stops working again.
Updated app on iphone yesterday. Schedule not working for me either. Disables all cameras. Very annoying - would assume a legitamite company would verify their app updates before pushing them out to their customers. Guess we know how they feel about us.
Still doesn't work. Schedule works via desktop app but not iphone app. Does not follow schedule - should be armed during the day, but all cameras disarmed. Have to arm them manually. Very dissapointing. Anyone from netgear reading these posts?
Wow. I can't believe Netgear hasn't fixed this issue, yet! These "security" cameras are completely useless.
Here is your fix, when Netgear will not help, I will.
One of my cameras just sent a push notification that a wasp had flown in front of one of my cameras. It showed a beautiful picture of the wasp. However, two other cameras failed to notify me that the FedEx truck drove into my garage and two people delivered a package. Recorded the movement but did not show as being in the library. Version 2.5.1 has not fixed the problem. Also, some of my cameras seem to have lost sensitivity and movement must be closer to activate the recording. With 15 cameras, I'm not happy.
Is there a fix for Monday not sticking on the schedule setting? This is annoying. Tried to set all weeknights to be the same or set Monday separately and nothing works
The device, iOS, Android, Web interface appear to be irrelavent. Whatever executes the schedule has been broken, a pushed base station update or something. I can only speculate. I've had Atlo equipment for 3 years and the system has been rock solid until a few weeks ago. The silence from Netgear and lack of a fix for this make me question their commitment.
At least roll us back to a previous version until you get the new functionality working properly.
I NEED SCHEDULES WORKING!!!
I just set up a new Arlo Pro 2 set, found couldn’t schedule for Monday’s either. Worked out that starting a Monday schedule at 12:01am seemed to stick (rather than starting at 12:00am).
Every other day is fine scheduling to start at 12:00am so don’t know why that’s a bug.
Use a computer browser for this function. Seems to work better.
A new version of the iOS mobile app is now available from the app market: Release Notes - iOS App 2.5.5 -12th August 2018
Please make sure you have the latest version installed.
Yes. I just went outside to make sure my garage door was open and fully expected to get a push notification on my front camera. I didn't. When I checked, it the mode was correctly on schedule, but the current activation was "disarmed". Oddly, "disarmed" isn't on my schedule ANYWHERE. It should either be front camera only, or both cameras, all the time.
I changed my schedule to armed and tested it and it worked fine, then set my mode back to schedule and it correctly listed "both cameras".
This is getting ridiculous. This system has just been one headache after another. I have no faith in the product any longer when it can suddenly and unexpectly stop working in the most bizarre ways.
FWIW, I find that using a browser for modes, rules and schedule works better.
Laying aside the absurdity of "works better", I did use the browser to create these schedules. It's not terribly complex, there's a period in the middle of the day where I only want a single camera to be armed, and then at night, both should be armed. Disarmed, isn't an option and should never be enabled by schedule.
I wish I had read these reviews before buying the Arlo Pro a week ago. I, too, am not receiving notifications for one of the 2 cameras. It is not sending notification when it detects motion. I called tech support and the woman told me that this has been an issue and they are working on fixing it. She said re-syncing everything works 90% of the time. The last support person told me to create a custom mode. That made matters worse because now neither of the 2 cams are sending me notificaitons. NOw I am told to bring the cam inside the house and re-sync to the base station, uninstall and re-install the app. I might call tech support tomorrow and try this. If that doesn't work, back to the store this goes. I would have done better with a dummy camera costing $10. I paid $500 and cannot understand why Arlo continues to sell thi product if there are bugs that need to be worked out! Arlo said they can replace the cams free of charge but I would have to pay for shipping!!! Not doing that. The online store where I bought the product will pay for shipping. This thing is turning out to be junk. I bought it because a friend who bought his Arlo a year ago talked about how wonderful this thing is. I guess they didn't make it with bugs a year ago. Very disappointed and would not recommend this product. I don't have time to spend hours with tech support.
Notifications worx.
Try clearing your schedule and go through set up again. Be sure each time frame has the correct desired mode scheduled.
