On othe Arlo app, for Android, when I have geofencing enabled I have a notification that states "Geofencing is enabled". I have push notifications turned off and I want to disable this notification as well; however, I still want to use geofencing. Any help is apprecaited.
@H4wks, did you read the rest of the thread? It's not going to go away. It's how they're currently keeping the app active so the geofencing works.
Has this issue been resolved?
Same issue here on my oneplus 5t with android 9. Hope this gets figured out soon so I don't have to force close the app every time the notification bar fills up with arlo alerts.
There's only the one alert that doesn't clear. All the others swipe away like normal.
like HotdogBattle mentioned, I can confirm this as well!
The option I get on a long press is to turn off notifications. Not what I want to do.
Problem solved! Thanks very much!
