Is someone having the same problem ? I have arlo pro and I installed the new app for Arlo (Android device) and after this I'm not receiving my notifications at all , is recording fine but I'm not getting push notifications . Can someone help me or this is a problem with the new app for Arlo ? Thanks
Are all permissions for the app in the phone settings allowed? Check the Notifications in Settings and verify that things are enabled. If emails are missing, verify that your modes and rules have things enabled and that the correct email address is used. Test using a different email address.
Android or iPhone?
The first thing to try is to reinstall the app.
If that doesn't work there are some settings you could try here: https://community.arlo.com/t5/Arlo-Pro/Arlo-Android-device-No-notifications-with-new-app/m-p/1725047...
I honestly don't think it's anything end users can control. My new app stopped receiving push notifications on 9/10, then magically out of nowhere, 2 days later everything started working again. Nothing was done on the base station or with my app, they're messing with stuff on the back end. Ever since 9/12 I've been receiving push notifications again without any user intervention.
This is a baby monitor that can't be used at the moment.
I think it would be very beneficial for Arlo to reinstate the old app until they get the bugs worked out of the new one.
I, like many others have downloaded the "New/updated" app 9/12/19. I have an LG V50, running current Android version. All settings set correctly for push notifications. I have reinstalled the new app multiple times, still no push settings. I created a new discussion as this issue has been marked as solved in recent threads and it's not. I am also unable to loacate the legacy app in the google play store.
Frustrating is the least I can say right now.
I couldn't find it yesterday either. Not sure what happened there (might be on Netgear, and not Arlo).
But you can still sideload it via https://www.apkmirror.com/apk/netgear-inc-2/arlo/
New app and no longer receiving notifications. This seems to happen with every app "upgrade." I get the notifications on my IPad, but I'm not getting them on my android phone. It's very annoying.
Thank you. I will try that.
@StephenB wrote:
I'm now receiving notifications. I cleared the cache/data from the app, restarted the phone, and then logged back in the app. Prior to this action, I tried just about every recommendation on this message board without any success.
I have performed this action. The last time I did it, push notifications worked for a few hours and then stopped. I will report back in a few hours with an update. Appreciate your input and reply.
