I have not been able to find a single reference to what you can use to charge or power these Pro 5S cameras and all they come with is a cable with a usb connector. The block that came with my original Pro cameras says it's5v/1.5A or 9v/1.1A. Can I use this?
I don't see any power adapters available for sale, only the (very expensive) charging station. And even that does not list the Pro 5 as a compatible device.
Any 5V, 2A USB charger should work fine.
Thanks for that. Is that the actual spec or is this just a "we tried it and it works"?
More like the latter but it's the same for all Arlo cameras that have come with a charger. Only the Pro and Pro 2 cameras used the Qualcomm QuickCharge 9V chargers.
It would be good to have this on the datasheet and manual.
@JamesC : Maybe an KB article showing charging requirements for all cameras?
So, if you buy the 3 pack of cameras, you actually DO get an AC adapter. I saw
P/N: 332-50110-02
Model: 2AEA010BA3B
Input: 100-240V~ 50/60Hz 0.35A
Output: 5.0V--2.0A 10W
So, yes, 5V, 2A is the spec.
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
