  • 5 Replies
  • 1718 Views
doncaruana
I have not been able to find a single reference to what you can use to charge or power these Pro 5S cameras and all they come with is a cable with a usb connector. The block that came with my original Pro cameras says it's5v/1.5A or 9v/1.1A. Can I use this?
I don't see any power adapters available for sale, only the (very expensive) charging station. And even that does not list the Pro 5 as a compatible device.
5 REPLIES 5
Any 5V, 2A USB charger should work fine.
doncaruana
Thanks for that. Is that the actual spec or is this just a "we tried it and it works"?
More like the latter but it's the same for all Arlo cameras that have come with a charger. Only the Pro and Pro 2 cameras used the Qualcomm QuickCharge 9V chargers.
It would be good to have this on the datasheet and manual.
@JamesC :  Maybe an KB article showing charging requirements for all cameras?
doncaruana
So, if you buy the 3 pack of cameras, you actually DO get an AC adapter. I saw
P/N: 332-50110-02
Model: 2AEA010BA3B
Input: 100-240V~ 50/60Hz 0.35A
Output: 5.0V--2.0A  10W
