Being caught by the end-of-life of my current set of cameras (Pro 2), I must buy all new cameras.
Arlo Support suggested moving to the Pro 5S. However, the Pro 5S connects directly to wifi, without a Hub. Can the Pro 5S connect to a hub instead, to support recording on local storage as well (e.g. USB external drive)?
The EoL date for the Pro 2 was just changed to 1 January 2025, so about two years from now. Also, Arlo removed the statements about removing 7-day free cloud storage. So no need for a subscription (or direct access to local storage) if you continue to use the Pro 2s.
So you don't need to anything right now.
Yes. See
Yes. See
Also, EOL doesn't mean your cameras immediately stop working. They will not get updates, features may stop working and free cloud recordings will cease. Buying a subscription gets you cloud recordings but wait until they are going away unless you want the extra days storage or some other feature.
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
