In and out of connection
This is getting ridiculous now. I have 2 cameras with CVR plan.. my Ultra 2 works just fine I have it mounted outside in front of my house. The Pro 5 is on the side of my house however it keeps going offlin. Then comes back online then back offline. there’s days it stays online and days on and offline constantly.. my router is right above both cameras what is the issue I even tried a spare camera on the side of my house and it’s the same issues on and offline
If you swap the Pro 5 and the Ultra, does the problem move?
Yes same problem
@Jcapache41 wrote:
Yes same problem
Even though it is close to the router, there might be something on the path (perhaps in the wall) that is blocking the signal.
I suggest measuring your home wifi upload speed at that location with your phone. Speedtest (the free Ookla app) is a good way to do that.
Thank you I am going to try that and will let you know
It was online from 11:30 last night until 1:00 this afternoon now it’s back offline. how does that happen where it’s just going off line like this
Jcapache41,
I'm working with the development team to better understand the issue you are experiencing. Please let me know if/when the camera comes back online.
Keeps going on and off line
Jcapache41,
If you temporarily move the Pro 5 camera inside, close to your base station as a test. Do you still experience the same behavior?
Nope works fine.. but I need that camera in that spot where I am having the issue
Jcapache41,
This would suggest that something at the location is causing the issue. Physical obstructions can reduce signal strength and cause the symptoms you're experiencing. If the issue only occurs at that particular location, this likely means there are too many physical obstructions between the camera and the base station. You can read more and find tips on what to do about this here: https://kb.arlo.com/37/How-do-I-position-my-Arlo-wire-free-camera
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
