Will a battery still be required if I use the cable plugged into house current?
I am upgrading to the 5S 2K camera and have a question about using the 25' outdoor cable. Will a battery still be required if I use the cable plugged into house current?
Forgive me if you’re already aware of this but you cannot wire the house electrical mains power wiring to the camera extension cable. You need a 5vdc charger or a compatible solar panel.
If you intend to run the camera without a battery installed you would need a charger.
@DannyBearAgain: The Arlo outdoor "cable" for the Ultra/Pro3/Pro4/Pro5s cameras includes an integrated adapter. So it is plugged in the house current.
You won't need the battery. Though there is some benefit to keeping it, as the camera will keep running if there is a brief power interruption. Arlo cameras do have overcharge protection, so it is safe to leave them in.
The main reason to remove the battery is that some Arlo cameras will run at lower temperatures w/o the battery - below the spec'd limit of -20C/-4F. No idea if that is true with the the Pro 5s or not.
5s
Accessing Local Storage
Accessing Local Storage.
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
detection
drained battery
Firmware Update
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
wind
wireless
Zones
