Ryedany
Two of my Arlo cameras have had water get inside them. They’re supposed to be made to be outside. This is upsetting!!
63 REPLIES 63
Smithnmore
The phone call is almost identical to the chat. Do not waste your time. The only way I got help was a support member on this thread sending me a message.
Film
I have noticed they seem very responsive in this community so that's a great idea.  I'd do that if I had to do it again.
KKS-Col
Luminary
Luminary
I just experienced this problem after moving a camera into a location without cover (since it is supposed to be waterproof). It developed a water “spot” in the middle of the lens. It appeared to dry out, somewhat, but remained hazy in the center of the image. I decided to replace it with another pro 5 that had been working fine. First drizzle and guess what, same exact problem. Faulty design. Of course there was no notification to customers of potential problems, you just have to ruin some cameras and then research on community to discover a host of folks with the same problem. Are you getting worse and not better, Arlo?
Have you (carefully) cleaned the lens?
Smithnmore
It sucks, because I have always had arlo but yes this is a big big problem. Especially when the chat told me to move them indoors or under protection from direct elements 😂
Record_Hound
I have an Ultra 2 inside a Total Security Mount that quit working. I pulled it out of the housing and water poured out. I tried to chat with support - and as Premium subscriber I'm supposed to get quicker help, but I was put in a que with a 120 minute estimated wait.
Any reason the Total Security Mount would be more likely to have water intrustion? The o-ring is fine and the camer tilts downwards anyway...so It seems the water came in from the back where the pivot ball is.
My app also has a message saying this camera reported being too cold before it went offline - but it's summertime so that didn't happen!
Record_Hound
Well, about 5 minutes after I posted in here support called me back and was very helpful!
DamianH217
Hello Arlo Community and Support,
I have 6 Arlo Pro 5s Cameras.
I had 5 of them get moisture inside the lenses.
I had support exchange one of them.
Now they refuse to exchange any more.
I am trying to explain to them that I shouldn't need to purchase NEW cameras.
This issue is not MY fault as their WATERPROOF cameras somehow got moisture in the lenses.
I am more than happy to just have a simple exchange as I already had months of back and fourth for one camera.
Many support chats later with all of the evidence they asked to see.
It seems they are now unwilling to follow up on their promises to me.
I would rather get this resolved here than do research, gather evidence, and have this resolved outside of support.
Anyways, hope you can be of assistance.
Thanks!
qtrayhart
When is Arlo going to fix the issue of "internal" lens fogging?  Camera is useless much of the time because of poor image quality!
DamianH217
Yep I am seeing it too… seems this is a widespread issue.
qtrayhart
Will do, thanks!
geoffsmail
I just discovered the same problem after recent rains.
There is water that has gotten inside where the lens is.  The rest of the camera is dry as a bone.
geoffsmail
I ended up fixing mine myself....  All you need is a small Phillips head screwdriver and a ziploc with some desiccant silicone packs.
As it turns out, the lens is made of molded plastic and you cannot get inside the actual lens.  But you can remove the lens (it unscrews) and then stick it in a ziploc with the desiccant packs for several days and it should do the trick.  It did for me.
Take pics as you go so you can tell how everything goes back together.
Remove the battery first... Then remove the 4 internal screws that hold the body to the face.
Then remove the 3 tiny screws that hold the circuit board on.
I use a bowl to hold the screws (2 types).
There is a small rubber grommet you don't want to lose, so go slow and work over a flat surface so you don't lose any of the parts.
Unscrew the lens, held in place with soft glue/sealant.
Put lens in zip loc with desiccant until the water vapor is gone.  Will probably take days.
Reassemble using your pics.
Good luck!
Aprilfool
@geoffsmail
Geoff - Your information is all well and good.  However, it should absolutely not be necessary.  We have each purchased what we believe to be quality security cameras that can be exposed to the elements - rain/snow/sun/etc.  We, as consumers, should not be concerned that we have to take down our cameras and take them out of service for days at a time to get them to dry out.  Arlo needs to do better.
