  • 4 Replies
  • 2811 Views
  • 2 Likes
Dogbert888
I purchased 3 Arlo 5s 2k cameras with the total security mounts. I don’t want to use these mounts as I have a cinder block cement house and want to use other mounts that attach around a downspout with the typical screw in just like I do with my Arlo pro 4s. I can’t find the screw hole or a way to remove the total security mount so that I can use any other existing mount with the typical screw thread. Do I have to return these as they seem like one piece shells.
Yes, they are one piece.
You could buy replacement housing and mounts (pro 4/ultra housings will work), but exchanging the cameras would be cheaper.
Dogbert888
Thanks for the reply and confirmation, I got this bundle w 3 cameras at a very good sale price but can’t use these mounts so I guess I will order regular housing mounts which would bring me up to just under the sale bundles price with regular housing. Then if I sell these mounts at half or less price I would still be doing really great. Maybe even find a trade as these are much more expensive but useless to me.
MSteadman
I am beyond frustrated with these mounts....   have to do a handstand on a ladder to get to the camera - that's if I can find the little tool that's now required....  to exchange the battery....  why the hell did they do this!?!? the magnet system was fine...  regrets
It's a security mount which isn't supposed to be easy to overcome.  However, if you check the accessories for the Pro 5 you'll see you can buy a separate case for it that then would allow you to use the magnetic base or a threaded mount.
https://www.arlo.com/en-us/accessories.pro5
