Time zone incorrect
  • 2 Replies
  • 3523 Views
Malzone
Just got rid of the base station. Only have 5 cameras, pro 4s & 5s and the time zone setting is incorrect, but I can't find the zones anywhere in cam settings or on the profile page on web. I also wasn't prompted when I set them up directly to wireless without base station. Help!
If you entered an address for the location, then the Arlo Cloud figures out the time zone.  There is no way to override it.  You can try changing the address, and then changing it back.
If you didn't enter the address, then
  1. click on the profile icon
  2. select "home"
You'll see the time zone there.
  2. select "home"
Malzone
Thank you that worked!
