Pre-Purchase Questions of Public Entity
We are looking at, to start, 7 Pro 5S 2K cameras. 4 outdoor and 3 indoor.
Due to the size of the building and location of Switch Stacks, we are unable to use the Ultra 2's. With cinderblock walls it's a tomb, but we do have AP's throughout the building.
Questions:
Can the web portal display more than 4 cameras at once?
Can there be more than one display signed into the portal at a time?
Can anyone weigh in with their experience using Arlo in a semiprofessional environment?
I'd really like the Arlo solution to fit as I've had peers use them in other situations with great success.
If we can get this to work, we could expand the solution and there is the possibility of it expanding to other public agencies we partner with.
Arlo Pro 5S 2K
Online Web
wireless
1) The display of cameras is related to the video resolution used on the computer as well as the size of the camera widget. The widget is add to the Dashboard screen while for the Devices screen you can't set the size. A little trial and error may be needed.
2) Yes, multiple people can view the portal at one time. There's 2 ways to do this - share cameras with other email addresses which can be used to limit what the others can do (or not) or to provide the primary user's credentials to all authorized personnel which gives them full access to the system.
3) I've only used the system in a home environment - sorry.
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
