I purchased 3 Arlo 5s 2k cameras with the total security mounts. I don’t want to use these mounts as I have a cinder block cement house and want to use other mounts that attach around a downspout with the typical screw in just like I do with my Arlo pro 4s. I can’t find the screw hole or a way to remove the total security mount so that I can use any other existing mount with the typical screw thread. Do I have to return these as they seem like one piece shells.
Yes, they are one piece.
You could buy replacement housing and mounts (pro 4/ultra housings will work), but exchanging the cameras would be cheaper.
Thanks for the reply and confirmation, I got this bundle w 3 cameras at a very good sale price but can’t use these mounts so I guess I will order regular housing mounts which would bring me up to just under the sale bundles price with regular housing. Then if I sell these mounts at half or less price I would still be doing really great. Maybe even find a trade as these are much more expensive but useless to me.
I am beyond frustrated with these mounts.... have to do a handstand on a ladder to get to the camera - that's if I can find the little tool that's now required.... to exchange the battery.... why the hell did they do this!?!? the magnet system was fine... regrets
It's a security mount which isn't supposed to be easy to overcome. However, if you check the accessories for the Pro 5 you'll see you can buy a separate case for it that then would allow you to use the magnetic base or a threaded mount.
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
