Use case: 4 camera inc. doorbell.
I want notifications at night and not during the day.
Can this be done:
1) at sunrise and during the day: no notifications from patio camera. I want it triggered by motion and sound.
2) at sunset and during the night:
notifications from the patio camera. I want it triggered by motion and sound.
I have tried creating an automation/routine schedule (Arlo, get your words consistent) when > sunrise, then > customize device: turn on all the next page. But, during the day I still get patio camera notifications.
I have been a software eng for 20 years. This app is driving me nuts. Arlo, hire a user experience company and fix this app.
Looking for help, thanks.
@KileyKiley wrote:
Can this be done:1) at sunrise and during the day: no notifications from patio camera. I want it triggered by motion and sound.
Modify "Arm Home" to arm the patio camera, but not send notifications
Then change the schedule automations to change the mode to Arm Away at sunrise, and Arm Home at sunset. instead of using customize device).
You're not alone, automations are a mess. Buggy, and IMO the user experience simply isn't well thought out.
I haven’t tried that. TBH, hadn’t thought of modifying the mode like that. I will apply this today and follow up. Thank you for the advice.
Above is the solution! Thank you very much. I have no idea how to use routines correctly and have given up trying to figure it out. I have the solution to my problem and can move on with life.
I cannot recommend this app at all. The cameras are very good and I’ve always been pleased with the wireless set up and performance of the cameras. The app is horrible: confusing, misleading, inconsistent, and frustrating.
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
