I have 8 cameras and an Arlo Secure plan.
I'm trying to find out if it's possible to:
- Have some cameras record all motion but send no notifications to my phone
- Have other cameras record all motion and send notifications to my phone
Does anyone know if this is possible?
thanks
It is. You need to go edit the rules in the mode(s) you are using. There is a rule for each camera, and that rule includes the option to send a notification (or not).
I am assuming you see "Feed" and "Dashboard" in your app menu (and not "Library"). If that is the case, this article might be helpful to you:
As the article says, the "Arm Away", "Arm Home" and "Standby" modes can all be modified (so you can use them in ways that are very different from what their names suggest).
This worked brilliantly. THANK YOU!
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
