Arlo Pro 5S 2K XL
I escalated this for you and someone from Support will be reaching out as soon as possible.
Try cleaning both connectors (camera and cable) with isopropyl alcohol. Also try a different charger that supplies 5 volts at 2 amps.
Thanks for your reply. I followed your advice, unfortunately that did not solve my charging issue. Today I received the VMA 5600c solar panels, placed them outside and still no luck getting these xl batteries to charge. Also, tried third party cable with no luck. The cameras work fine just cannot this xl batteries to charge!
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
