Arlo Pro 5s 2K & Aeotec Hub Only
  • 2 Replies
  • 526 Views
hudder
Title.
Is it possible to only use this as a setup? Can I use local storage as well? I’m having trouble finding specific detail on their site and in their listed info.
Thank you for any help!
@hudder wrote:
Arlo Pro 5s 2K & Aeotec Hub Only Is it possible to only use this as a setup?
No idea if it will work or not.  The camera is intended to either be directly connected to your home wifi, or to an Arlo Smarthub.  While you can integrate the camera into your SmartThings app, AFAIK there is no benefit in trying to connect it to a SmartThings hub.
Local storage requires that the camera be connected to a VMB4540 or VMB5000 smarthub.  The smarthub has to be connected to your router's ethernet.
ShayneS
Hi @hudder
Can you provide more detail regarding what you are trying to achieve with the Arlo devices?
