Is there a ceiling mount for the Arlo - Pro 5S 2K 3 Camera Indoor/Outdoor Wire Free Spotlight Security Camera? Or, what is the best way to mount on an overhang?
Best answers
@ps2 wrote:
if you are using the anti-theft mounts.
If you are using Arlo's anti-theft mount, then you will have to purchase a housing with the standard screw mount.
The camera has standard 1/4 inch screw threads, so there are a lot of third party mounts you can get.
Hello Stephen B,
Thank you for your timely response. I have seen the third party mounts but without purching one yet I don't see how they are compatible with the Arlo camera especially if you are using the anti-theft mounts.
Any suggestions would be greatly appreciated.
Thx
ps2
