I've tried everything I can think of to disable audio detection but to no avail. This camera detects even the slightest wind noise running down the battery very quickly. I have set audio detection to the lowest setting of 1 in the default settings menu. Also turned it off in Smart Notifications and Routines (Rules), Smoke & CO2 detection also set to off.
What am I missing?
Thanks.
Think I've finally figured this out. I have two cameras, a Pro 4 and Pro 5, both with identical routines. Disabled sound detection was working fine on the Pro 4 but not the Pro 5. I deleted then recreated the Pro 5 routine rules and now it's working fine, I assume somehow the routine got corrupted.
Thanks for the replies and help.
Did you try a hardware reset?
- remove the camera from the account
- open the housing and hold down sync until the LED flashes amber (~15 sec)
- add the camera back to the account
You're in the wrong place. Edit your modes and rules in Routines and toggle audio detection to off.
Thanks for the reply. No I haven't tried a factory reset, was hoping it was something easier before trying that.
Thanks, as mentioned I already did all that. But I did notice the microphone was still toggled on, does that need to be off for the modes and rules in Routines to take effect even though audio detection is toggled off?
It's ok to leave the mic on, that allows you to hear audio in the recordings (or livestream), and also use two-way talk.
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
