I believe there should be a feature where I can keep some cameras on armed during the night as I keep my house hold cameras on unarmed. What do you guys think?
That feature already exists.
If your pro 4s are connected to your home wifi, you can set up a separate schedule for each camera.
If they are connected to a base or smarthub, then you can still do what you want by creating a custom mode that has the cameras you want on at night included (and which omits the cameras you want disarmed). Then schedule the system to use that custom mode at night.
Arlo Pro 4
labels
Samsung SmartThings
