Library dates
I have 2 Arlo 4 and 1 essential.
Library does not show todays date until I logout and log back in every day.
I’m under trial period until May 2022.
I guess now thinking of there are no videos then maybe the calendar in library does not update? So five days from now if motion is recorded, then maybe the library date update?
Try making a manual recording while livestreaming, and then select the library (seeing if you see the right date range).
FWIW, I always see the current date listed (using the 3.6 app with iOS 15.4 at the moment). But I pretty much always get at least one motion recording overnight.
I occasionally find that I need to refresh the library by pulling down on the page to cause the refresh.
Arlo Pro 4
labels
Samsung SmartThings
